Feedback on NI Community
Suggestion: Go directly to solution
On multiple occasions I've tried clicking the little green check mark on a forum topic hoping/expecting to go directly to the marked solution.  I think it'd be great if one of these times it worked.
Tim Elsey
Certified LabVIEW Architect
(5,617 Views)
Hi elset191,
Thanks for the suggestion. I can see how you might expect the check mark to take you to the solution. We currently have it set to take you to the problem post first because the solution is typically not useful unless you know the original problem it is resolving. This helps ensure other users have read the actual problem before trying out a solution.
Jordan
(5,593 Views)
