Feedback on NI Community
VI for mouse interface
I am currently doing a project that will track the motion of the hand and acts as a cursor on the front panel. What i AM interested in is whether i can somehow communicate with the computer and acts as a mouse interface rather than using an "actual" mouse.
1.  Is there such a vi that will enable the user to communicate or take control/overwrite the mouse program?
2.  If it is not possible, is there any other posible way to do it?eg: connect a wireless receiver at the mouse port(like a wireless mouse) and
     send signals (x y coordinates) from another port of the computer through a tranceiver.
Please help. I really appreciate your expertise. Thank You
(5,570 Views)
You posted to the feedback board. You should have searched and then posted to the LV board.
If you had searched, for instance, for "simulate mouse", you probably would have found some VIs which demonstrate how to call the operating system to simulate mouse movement and clicks. In windows, the specific API functions are SetCursorPos and Mouse_Event and if you search for those terms you should find some VIs.
___________________
Try to take over the world!
(5,560 Views)
oops!
Think i might have made a mistake. Thanks for informing though. And Thanks for your information. I'll post it up under the LV most active sofware boards. Thanks
(5,551 Views)
