Feedback on NI Community
Why do I get someone elses Activity when I login
When I login to Discussion Forums I get someone's activity.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=167&HUserId=101_43756&HMy=Yes
I get Markp01. I cant edit his profile but I can edit his subscriptions.
As you can see from the name posted by this question. It should be from Ray Farmer not markp01.
What's going on?
Regards
Ray Farmer (ray.farmer@talk21.com)
(4,451 Views)
Hi Ray,
We have been experiencing some intermittent problems with the Developer Exchange. We have seen this problem before, and we thought that it had been fixed. Clearly, it's still an issue. I will talk to our admins to see if we can come up with a solution, and I will follow-up with you via email.
Sarah Patterson
(4,451 Views)
Ray actually solved this issue by changing his security settings on his browser. Apparently, his logon had failed or been restricted, previously, but he was unaware of that fact.
In IE, he went to Tools>>Internet Options, Security Tab.The Security settings for Logon was set to 'Automatic logon only in Intranet zone'. When he changed this, he was able to login correctly.
(4,451 Views)
