Feedback on NI Community
Wrong Behavior in forum table resize
Look at the attached image.
When an author name is very long (circled in red), it should be the one that is split on several line and the topic (thread) should be kept on as few line as possible otherwize you end up with that ugly result as seen on the image.
PJM
As a side note, apparently this forum does not accept PNG file.....
vipm.io | jki.net
(3,637 Views)
PJM_LabVIEW -
I will see what they can do about the table size issue - thanks for reporting it!
I have added the PNG file format to the list of acceptable attachments, so you should be able to add those from now on.
Thanks for the feedback!
Molly K.
Web Support & Operations Manager
(3,623 Views)
