Feedback on NI Community
can't open NI-DAQmx8.5
I downloaded NIDAQ850[0].exe and DeviceDoc850[0].exe, but when i tried to open these files in a windows vista system, then appeared this error message: "Zip file is damaged, truncated, or has been changed since it was created. If you downloaded this file, try downloading again.", i downloaded the files again, but i get the same problem, so i  used a file repair program to fix these files but it doesn't work, so i don't know the reason for this message, i read a similar topic but i don't  understand the answer.
thanks in advanced
PD1: excuses by my english
(6,299 Views)
Hi Anlasa,
This question should be posted on the Multifunction DAQ board
This is an area (FeedBack on NI Forum) to provide feedback on the functionality of the NI Discussion Forums.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(6,289 Views)
