Feedback on NI Community
changing individual tags
I am using tags to mark some messages of interest, i.e. 'bug' or 'open_question'. Now it happens that this question gets resolved or a bug fixed and I would like to change the tag for a particular message - all I found is to delete / replace this tag for all messages. Obviously, resolving one open question does not solve all my open questions.
Is there a possibility to change a tag in a specific post only?
Wolfgang
(6,727 Views)
Accepted by topic author Wolfgang
Hi Wolfgang,
The process is a bit convoluted, but I believe you should be able to delete a single tag on one message by doing the following:
1. Go to the message, and click "View All" next to the tags
2. On the next screen you will see just the tags for that message, under "Tag Options", select "Manage my tags"
3. On the next screen, you should be able to individually select the tags from that particular message that you want to delete.
Let me know if that works for you.
Thanks!
Laura
(6,709 Views)
Thanks, Laura, this approach works.
(6,686 Views)
