Feedback on NI Community
how do you view text in LV community forum?
I asked in the breakpoint here.
Its no wonder there isn't any (very little) non-NI content in that forum. I just don't get how to use that site!
Ben
(7,048 Views)
This is practically the only one I visit... The discussion forum..   I'll have to try to visit the community forum...  😉
(7,015 Views)
Hi Ben,
Have you checked that document recently?  I wonder if you caught it when it was being updated or something, because I can view the content.  How about other documents? Can you view those?  Here's an example that should have some text and then an attachment.
Laura
Edit: I see your update in Breakpoint - you are correct, there was some site downtime over the weekend.
Message Edited by Laura F. on 07-22-2008 01:32 PM
(7,007 Views)
I can read both.
Will it ever be possible to combine the login for both forums?  or are they completely separate forums (I know they are separate...)  but is there a way to combine or duplicate similar login so it is transparent to the user?
R
(6,994 Views)
Look like this to me...
Message Edited by Graziano on 07-23-2008 08:01 AM
(6,983 Views)
Hi Ray,
The logins both use your ni.com user profile information.  The email address you use to log in to both the forums and the community is the same, and the alias is the same as long as you are using that same email.  You will need to set up your avatar again in the community.
Let me know if this was not what you were asking.
Thanks!
Laura
(6,977 Views)
okay...  I didn't try recently.. Wasn't it different back in the days??   I will try login in. THanks 🙂
R
(6,968 Views)
