Feedback on NI Community
icon problem
Hi
      I'm not getting my sleeping lion icon lately. can anyone sort it out
Regards
RobinHood
Message 1 of 8
(8,418 Views)
You dont seem to have posted an icon to either your image gallery or to the following link
http://forums.ni.com/ni/board/message?board.id=130&thread.id=1948 (looking at your post history)
which means you were probably linked to a local pc and that has changed or you deleted the files.
You need to put your icon in the Image Gallery or the above link and then use this to set your icon link.
hope this helps
Ray Farmer
Regards
Ray Farmer
Message 2 of 8
(8,409 Views)
He was well aware of this.
Mathan
Message 3 of 8
(8,406 Views)
The link that you provided for your icon is no longer working:
http://www.winthropharborlionsclub.org/sleeping_lion.jpg
You need to provide a working URL that hosts the image that you would like to use as your icon.  As Ray mentions, you can either upload it to your image gallery or attach it to a forum post in the icon thread.  Once it is uploaded to either place, edit your profile and on the icons tab either select the icon from your gallery or put in the URL to the icon if you attached it to a forum post.
Laura
Web Support & Operations
Message 4 of 8
(8,400 Views)
Mathan, some of you had asked me to post this thread on "feedback on Ni discusiion forums".so, I've posted it here.
Regards
RobinHood
Message 5 of 8
(8,364 Views)
Hi Robin Hood,
did you change the url in your profile? If you now use the url to the posted image, then it should work as your icon.
Mike
Message 6 of 8
(8,359 Views)
Laura,
I give up !!!!!!!
Whats the path to one's Image Gallery
thanks, Raul
Message 7 of 8
(6,599 Views)
Your image gallery is here.
Maybe it does not contain any images yet.... It could also be that it requires a certain forum rank.
Message 8 of 8
(6,588 Views)
