Feedback on NI Community
image compression whit wavelets
  is that you can help me?
hello,
  I made a prog that makes the wavelet image compression but
  I found some problems, it gives me nothing.
thank you so much
Message 1 of 9
(6,830 Views)
You posted a question in the forum that is for feedback on how the Discussion Forums operate.
You need to post your question in the LabVIEW board.
Message 2 of 9
(6,824 Views)
This sounds more like a matlab problem.
Message 3 of 9
(6,818 Views)
You're right.  I hadn't opened the VI to see there was a Matlab node in there.
Message 4 of 9
(6,811 Views)
Unfortunately, we don't have a matlab board. (I don't know if these functions are also supported in mathscript.).
(You are also using a toolkit that is not part of plain LabVIEW. Maybe the vision board would be more appropriate.)
Message 5 of 9
(6,807 Views)
but how can i put my VI in LABVIEW board ?
Message 6 of 9
(6,801 Views)
You can click on "options...report to moderator" (upper right corner of post) and aks for the thread to be moved elsewhere.
Message 7 of 9
(6,795 Views)
 sorry , i dont find it , can you transform my VI to LABVIEW board ?
Message 8 of 9
(6,787 Views)
Message 9 of 9
(6,762 Views)
