Feedback on NI Community
implicit timing setup and read counter data
     I have a question on how the implicit timing on a frequency input works.  I am inputting a straight frequency into a counter input on a cDaq unit.  I set it up using the 20Mhz Timebase. and counter 0, However If for example I input a 10Khz frequency and read data from the read counter vi every 10ms I would expect to see 10,000 * .010 samples or ~100 samples per read right?  I am only seeing about 10 samples per read though.  Am I not figuring something right?  I am setting up the sample clock as implicit using parameters (continuous, 200000 buffer size).
(5,544 Views)
The feedback forum is not for techical questions. Please ask the moderator to move your post.
(5,543 Views)
