Feedback on NI Community
sheet reorder
Is there a way to reorder the sheets so that the renumber of parts will work correctly? Several sheets in my design have been moved by dragging the tab for the sheet to the desired location and the part renumber tool uses the original sheet order when renumbering the parts resulting in an incorrect renumber.
KK
Newbie at this point
Message 1 of 9
(7,471 Views)
I have no idea what NI product you are referring to but your post certainly does not belong to this board.
Message 2 of 9
(7,466 Views)
Message 3 of 9
(7,450 Views)
Why on earth would you say to post to the LabVIEW board. Sheets and a design sound more like a schematic capture.
Message 4 of 9
(7,436 Views)
The task of reordering the sheets is a Multisim 11.0 question.
My apologies for not stating that in my original post.
I did get past the issue by generating a new set of sheets for the design and copying the part to the new sheets in the preferred sheet order and then deleting the original sheets. Then the part renumber tool renumbered the parts correctly.
Thanks for the help.
Message 5 of 9
(7,432 Views)
Message 6 of 9
(7,429 Views)
I got it as excel sheet.........:smileyindifferent::smileyindifferent:
Message 7 of 9
(7,411 Views)
natural mistake..  unless you've done hardware..  😉
Message 8 of 9
(7,403 Views)
I have and i should have taken the
sheets in my design
 hint...
Message 9 of 9
(7,389 Views)
