Feedback on NI Community
size of the dashboard window
The dashboard panel doesn't size correctly.
Since I added a bookmark I cannot see the logout link on the dashboard.
I can manually resize the window but as soon as the window refreshes its back to the original setting (See attached bmp).
Is there some way of getting to size correctly.
Regards
Ray Farmer
Regards
Ray Farmer
(4,321 Views)
Ray Farmer -
I have searched through the configuration options that I have access to in an attempt to find the default window size for the dashboard. Unfortunately, I haven't been able to find it yet.
I will continue to investigate to see what we can do about getting it resized.
Thanks for the feedback!
Molly K.
Web Support & Operations Manager
(4,299 Views)
Ray Farmer -
I tried to see what I could do about this, but I have reached a dead end. 😞 Unfortunately, the size of that window isn't something that is configurable.
Thanks for the feedback,
Molly K.
(4,281 Views)
Hi Molly,
ok thanks for the response.
I have removed some of the links so that the logout link appears in the window.
Regards
Ray Farmer
Regards
Ray Farmer
(4,272 Views)
