FieldPoint Family
1808 API - Examples
I am ordering a cFP-1808 to use with a PPC-2015.  Looking at the FP API I see there is a FieldPoint Network Read.vi on the Advanced>Ethernet Advanced tool palette.
Is it necessary to use this VI to communicate with the cFP-180x units or will the standard FP Read/Write VIs work as well?
Just wondering in advance of receiving the unit.
I did not see any examples when I searched the examples finder for cFP-1808.
Thank you.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(6,344 Views)
Hello RVallieu,
You do not need to use the FieldPoint Network Read to communicate with the cFP-1808.  This tool is used in conjunction with the Publish Data functions.  You will communicate with the cFP-1808 the same as with any FieldPoint controller, using the regular Read and Write functions.  The difference is that the application will not run embedded on the cFP-1808 since there is no controller, only a network module.  Using Read and Write, the data will be send directly through ethernet to the host machine.
Clint M
(6,327 Views)
