FieldPoint Family
AI-110 Module - What happens if Current input is shorted?
I have an AI-110 Module with 4 current inputs using a Vsup of 28vdc. What happens if Current input is shorted? Is the current limiting resistor enough to protect the module or should the power to the module be fused?
(3,106 Views)
The [c]FP-AI-110 modules are protected to 30 mA and have an input impedance of 100 Ohms. Thus, they can only handle up to 3 Volts without damaging the high precision input resistor. If a regular risk of short circuits is a possibility, you should add some protection to the system.
Aaron
LabVIEW Champion, CLA, CPI
(3,095 Views)
