FieldPoint Family
APPCRASH FieldPointOPC2.EXE with Visual Studio 2005
At seemingly random intervals the following error occurs while running application in the development environment and with the release  version. Is there any way to solve this?
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    FieldPointOPC2.EXE
  Application Version:    4.1.0.15
  Application Timestamp:    407206d3
  Fault Module Name:    LKSOCK.dll_unloaded
  Fault Module Version:    0.0.0.0
  Fault Module Timestamp:    45c36dca
  Exception Code:    c0000005
  Exception Offset:    700736b0
  OS Version:    6.0.6000.2.0.0.256.1
  Locale ID:    1033
  Additional Information 1:    ee0c
  Additional Information 2:    0f3137665bbf0bb676c8a16f3fa76e52
  Additional Information 3:    562b
  Additional Information 4:    58019b32234d4a81ca33d299b8e55c9b
Read our privacy statement:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
(7,151 Views)
What modules are you using? Please specify all your hardware. Is there a pattern to these crashes occuring? Which version of LabVIEW are you using? Are you using your VB program using DataSocket or some other OPC software? What exactly is your application? What operating system and specs does your computer have?
Can you please check the CPU usage while running the program?
I need a lot of information so I can narrow the use case down.
Warm regards,
Karunya R
(7,134 Views)
Please consider upgrading your FieldPoint driver to version 5.0 or higher.  This should fix the error you are receiving.  Post again if you continue to encounter problems and we will look to see what might still be wrong.
Eric A.
Distributed I/O Product Support Engineer
(7,120 Views)
