FieldPoint Family
An attribute of the project was changed
I am using LabVIEW 8.2.1 with the RT module to communicate with Compact FieldPoint devices. I have a project established which contains VIs for the host as well as others for the FP target(s). I have noticed that when I first open the project, the asterisk is present as though I had changed something (which I did not). When I try to close it, it asks me if I want to save the changes. When I click "List Unsaved Changes...", the only explanation I get is "An attribute of the project was changed."
Will someone please explain to me what that means and why it is happening?
David
(8,243 Views)
I was having the same problem on a cRIO application. I did a mass compile on the LabVIEW 8.2 directory and that seems to have taken care of the problem.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(8,234 Views)
Can't remember for sure, but I believe this was a known issue for LV RT 8.2 (and possibly 8.2.1); LV would claim that the project had changed when it clearly didn't since you are loading a project that you saved in that same LabVIEW. If I recall correctly, this has been fixed in LV 8.5.
J.Mota
(8,204 Views)
Sweet Champions logo, Ed! I had heard news we were creating one for you guys. I had no idea is was going to look wicked-awesome.
And I'm lovin the quote about the Abort button. I shared that with some other AEs and we all had a good laugh. We appreciate you spreading the gospel of LabVIEW.
Cheers,
Emilie K | Applications Engineer | National Instruments
(8,196 Views)
Cheers,
Yes, Jeffery and crew did a great job on the logo
I came up with that Abort button line while teaching a Basics class. It's something I tell all my classes now.
(8,087 Views)
Thank you, J. Mota for the upgrade suggestion. Although I have LV 8.5, I am not quite ready to upgrade yet for reasons that I will not bore you with. However, I will do it soon.
Thank you, Ed for the mass compile suggestion. I have never done a mass compile before but I tried it and it seems to be helping me in general. The project still awakens with the asterisk and the subject message but I believe I am on the right track because the project comes up much faster now. In fact, it comes up a little too fast because I can see a dialog box pop up for a split second probably telling me what it is trying to compile but it is too fast to capture. I believe this may be happening because I have shared variables in an unexpected subfolder.
I created a directory structure and project based on the new book by Peter Blume, "The LabVIEW Style Book". I noticed that my shared variables are not being placed quite where I wanted them. Probably if I could find the right location and mass compile that, it would work unless I don't understand how mass compile works. In my project folder I have been choosing Tools -> Advanced -> Mass Compile... then navigating to my top level folder where I keep source code and pressing the Current Folder button. If I need to do more or do it differently, please let me know.
David
(8,016 Views)
