11-28-2006 07:40 AM
11-28-2006 08:49 AM
Terry,
Using some sort of ethernet based hardware is probably the best bet. Cables that long make me nervous. I've had good luck with the compact fieldpoint units. Just remember that the analog input modules are not real fast. What kind of data rates are you expecting? Depending on the acquisistion rate, you may need to look at something like a Compact RIO.
Wayne
