FieldPoint Family
CFP2000 Unable to find IP address
I have recently reset my CFP-2000 to factory settings, and it does not register its IP address with my router or it does not have one. I have moved the DIP switch multible times, but am unable to find it.
My Network is set as such
10.0.0.0/28
10.0.0.1 -Router
10.0.0.2 -10.0.0.6 -Open DHCP
10.0.0.7 PC with MAX and Labview
10.0.0.8 -Open
The cfp does not appear to be accepting an IP address from the router. How can I target this device to set the IP, or have it acquire one from the DHCP host. I do not have a serial cable to RS232 into the device.
The device currently blinks red to state that it is at factory setup stage
(6,535 Views)
Accepted by topic author KhaosTheory
The device appeared to be stuck in a watchdog. I have found the problem and now am able to use.
(6,528 Views)
