FieldPoint Family
COM1 Missing on cFP-2100
BRAVO!
* The crowd applauds wildly
So it sounds like the MAX installer applied the .ini file for a 2120 instead of a 2100.
Simple fix.
.ini Attached for posterity.
Tim L.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 21 of 25
(3,503 Views)
Hi Chris, hi Tim,
PERFECT!
I had the same Problem, using cFP-2100 and FieldPoint Drivers 6.0.9. I could not use the COM1 on the cFP. I removed the three paragraphs in the ini-File as you mentioned and rebooted the system.
Now it works again!
Thx!
CaDu
Message 22 of 25
(3,492 Views)
Glad to hear it's helping!
I have actually created a KnowledgeBase article at ni.com to document this issue in case anyone needs more details: Why is the VISA Drop-Down Box on my cFP-2100 Empty?
Have a great day,
Chris V
Message 23 of 25
(3,484 Views)
Chris,
I have migrated to LV11 and the problem appears to have returned,
Any suggestions?
Message 24 of 25
(3,434 Views)
Ignore previous message,
I have just completed a clean format and re-install and was successful.
Appologies for the inconvenience.
Message 25 of 25
(3,431 Views)
