FieldPoint Family
Callers path signification
What does men "callers path" in FPOptohandler.vi ; What must be wired to this ?
(3,751 Views)
Franck,
The CallersPath in the FPOptohandler.vi should be wired to the constant CurrentVI's Path found in the File I/O --> File Constants Palatte. However, you should not be needing to do anything with the FPOptoHandler.vi since it is a subVI of the FieldPoint Optomux VI's. Is there some function you are trying to implement that is not covered by the FieldPoint Optomux VI's?
Aaron
LabVIEW Champion, CLA, CPI
(3,750 Views)
Hello Aaron,
The function I try to implement to my VI is the power-up clear of which we have told a lot last year. I lost some files and I can't remember how using the A command with the FPOptoHandler.vi. But I'll try to wire the currentvi's path. thank you very much.
Regards. Franck.
(3,751 Views)
