FieldPoint Family
Can Aggregate Objects be edited after inserting into a process?
After saving a process as an Aggregate object I use it into another process.But then I cannot edit a text box to or rename anything.Is it normal?
Also I wish to use labels which takes up its values from a tag name.Can it be done in Lookout?
(3,271 Views)
Hi
First of all, this question would be better answered if posted in the Lookot discussion forum, in the Fieldpoint discussion the Lookout enthusiastic people will not see your question.
Second, no, the aggregate object cannot be edited once it has been generated. The idea of the aggregate object is to generate an new object which is comprised o a combination of others. In this process you can choose to expose parameters and/or data members, and this as the ones that you can edit and/or access programmatically latter when you place the aggregate object in your program.
Regarding to your second question, no it is not possible, what you can do is to use the TextEntry object, but you cannot read tag names to write to it.
Regards
Andre Oliveira
Appli
cations Engineer
(3,271 Views)
