FieldPoint Family
Can I embedded and run an application built by LabWIndows/CVI on Fieldpoint 2XXX?
(3,146 Views)
Hello Xu,
It depends on what version of CVI you have.
If you have CVI 7.x, there is no direct Real-time suppport.  You would have to use LabVIEW and LabVIEW Real-time to embed an application on the controller.
If you have CVI 8.x, you will only need LabVIEW Real-time in order to develop a CVI Real-time application.
Eric
DE For Life!
(3,116 Views)
