FieldPoint Family
Can a AI-xxx module be used to measure voltages in a system connected in series?
I'm intending to use the FP-AI modules to monitor the voltage across copper electrodes connected in series. According to the manual, the common terminals are each connected to each other within the module and would cause a short in the system when measuring voltages across different cells. Is there a model available to have a different reference to the input voltage in each channel or a way to set up the 110 or 112 without causing a short?
(3,106 Views)
The cFP-AI-118 offers channel to channel isolation (750 Vrms) allowing each input to have a seprate ground.
Aaron Gelfand
LabVIEW Champion, CLA, CPI
(3,102 Views)
