FieldPoint Family
Comm. problem with cFP RS485 4 wire to Yokogawa UP150 RS485 2 wire
cFP data sheet states that RS485 4 wire will not work with RS485 2 wire. I need to communicate with a bank of 6 Yokogawa UP150 temp controllers and 6 Overtemps, 2 wire system. I have seen some 4 to 2 wire converters on the web. I need to be able to use RS232 ports as well. I read a post about combining the 4 wire to 2 wire but it impacted the RS232 ports.
thanks
bruce leighty
(3,328 Views)
Bruce,
Here is a Knowledge Base on our website that talks about this very issue:
cFP RS-485 Port in 2-Wire mode
Hopefully this KB will address your question!
Craig H.
(3,300 Views)
