FieldPoint Family
Communicating to FieldPoint from HP-UX
Has anyone out there been able to communicate from HP-UX to FieldPoint modules? I have seen the technique of putting a program on the FP-2000 module that will talk TCP/IP. Is there any other solution?
(3,549 Views)
I may be ignoring the easy solution here. Can LabVIEW for HP-UX communicate efficiently with FieldPoint modules?
(3,549 Views)
Mike,
At the present time, the only way to communicate from an HP-UX machine directly to a FieldPoint Ethernet module would be to use a FP-20XX series module and use either the TCP VI's or the UDP VI's. For the FieldPoint Serial Network modules you may communicate using the Optomux command set as documented in the FP-1000/1001 Programmers Reference Manual. If you are using LabVIEW on HP-UX, you should be able to use the LabVIEW FieldPoint Optomux VI's downloadable from:
ftp://ftp.ni.com/support/fieldpoint/LVFPOpto/
Aaron
LabVIEW Champion, CLA, CPI
(3,549 Views)
