FieldPoint Family
Compact Field Point Set up.
I have a compact field point system. I would like it to count TTL pulses for an RPM measurrement. How do I go about doing this. I have a counter and input module. Do I wire direct into in the counter module
or do i wire into the analog module. I have no field point experience....PLEASE HELP! Thanks!
(4,605 Views)
Hello Chris,
Thank you for contacting National Instruments.
The first thing you need to understand is the signal that you would like to measure. Our FP-CTR-500 and FP-CTR-502 can measure signals up to 50kHz. If the frequency of your signal exceeds 50kHz, you will not be able to measure it.
More than likely, the signal that you are trying to measure is coming from a shaft encoder that produces a finite number of pulses per revolution of the shaft to which it is attached. If you shaft encoder produces 360 pulses per revolution, then you will be able to measure RPMs up to 8333rpm. You can determine this by taking 50kHz/(360pulses/rev) = (138rev/s), (138rev/s)x(60s/min) = 8333rev/min
You may need to tweak this formula depending on the number of pulses
your shaft encoder produces in one revolution.
Next you must understand your measurement device. The inputs of the FP-CTR-500 are sinking. This means that your measurement signal must source current and be connected to some type of power supply. The
FP-CTR-502 has sourcing inputs, which means that the Vin terminal provides a path to a voltage supply which means that your signal must provide a path to ground.
Here are links to the manuals for the FP-CTR-500 and 502:
http://digital.ni.com/manuals.nsf/websearch/5AE49B0DECF9430286256D4A0061F5DA?OpenDocument&node=132100_US
http://digital.ni.com/manuals.nsf/websearch/FD58CA056D4A0062510A?OpenDocument&node=132100_US
Please also see this link to this tutorial:
http://zone.ni.com/devzone/conceptd.nsf/webmain/B3E3A26BBBBF9E1586256AF00059B86E?opendocument
Saving the best for last, her is a LabVIEW example program for measuring frequency with the FP-CTR-500/502:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=
B45EACE3EBA556A4E034080020E74861&p_node=174404&p_source=external
Bill B
(4,597 Views)
Bill,
Can you send me the links for the cFP modules as well. I need to figure out how to connect a laptop to them via simple 802.11b hubs. I believe I have the cFP with the removeabl memory slot.
Again, thanks for all your help.
Chris
(4,597 Views)
Chris,
Here is a link to the cFP-2020 User Manual and Quick Start Guide:
http://digital.ni.com/manuals.nsf/websearch/6958CEC71ED8D04E86256C8E005F1E0D?OpenDocument&node=132090_US
http://digital.ni.com/manuals.nsf/websearch/ECB47A1BBF22353686256C3300562186?OpenDocument&node=132090_US
Bill
(4,597 Views)
