FieldPoint Family
Connecting LabVIEW 8.6 to Omron PLC
Hi there,
i have to connect LabVIEW 8.6  to Omron PLC (CJ1M-CPU13).
I suppose LabVIEW 8.6 + DSC Module + NI OPC Servers will do the job. Has anybody experiensed with that?
Thanks in advance
(11,434 Views)
Dear metrisys,
You may find many resources on this topic:
Where Can I Find Drivers for Communicating to PLCs, RTUs, and Other Industrial Hardware?
http://digital.ni.com/public.nsf/allkb/13EE0A9E2C43F0DB86256A6100722651?OpenDocument
Communicate with Omron PLC
http://forums.ni.com/ni/board/message?board.id=170&message.id=250062&requireLogin=False
If you have any questions please feel free to ask!
Marton Litkei
NI Hungary
(11,396 Views)
Hi
I'm using the same hardware and software as you, I 've created a Client in Labview and about 110 shared variables connected to data memory of the PLC trought the NI OPC  Server. The application works not very well, I have some problem with the Variable engine,
it crash every hour that the application run.
Did you try already the system?
Please can tell me if you discover the same problems?
Any suggestion on this problem are really appreciate.
Regards
Vincenzo
(10,884 Views)
Hi enzo78 !
  Could you describe more in details what you experience when the error appeares? What is the error code you recieve? Do you run something before the error appeares paralell your application? Could you link some snapshots about the error message? What do you mean when you say the Shared Variable Engine crashes, are the variables not reachable?
  The system you described should work without of problem. If you provide me these information we find out what went wrong with your application!
David Varga
NIH
(10,855 Views)
Hi
Here I `ve posted the same question in this link http://forums.ni.com/ni/board/message?board.id=170&message.id=414534#M414534 I`ve attached the error message, please let me know if you need more.
Vincenzo
(10,850 Views)
Hi Vincenzo,
  I posted a possible solution to the original thread. Let's continue the discussion there!
David Varga
NIH
(10,843 Views)
