FieldPoint Family
Connecting two terminals with the same labview program to fieldpoint hardware.
I need to interact two different computer terminals (one in the lab and one outside the lab), with the same fieldpoint hardware. These terminals are linked to the fieldpoint hardware via an ethernet switch. Everthing passes through this switch (the FP1600 modules and the two computers). Both terminals are running the same VI program. Can this be done? If so, how?
(3,341 Views)
The FP-1600 natively supports multiple clients with no additional configuration required. Each computer will need FieldPoint Explorer with a configured IAK file. Beyond that, unless you have enabled security in the FP-1600 module, both computers will be able to access the FP-1600 without any difficulties.
Aaron
LabVIEW Champion, CLA, CPI
(3,341 Views)
