FieldPoint Family
Data loss in a FieldPoint system under heavy load
I am using a FP 1000 system with two PT100 modules and a Dual Channel module.Data are displayed in a CWgraph and read out via a DataSocket. From time to time I am receiving zero values if the computer is heavily loaded or if the TCP/IP network is busy(not used by FP1000). I suspect that "bad data" are not handled correctly in the OPC system.
(3,166 Views)
Updating FP Explorer might help since it will update the OPC server. The newest version is 3.0.2
Remzi A.
(3,166 Views)
Thank you for your answer,but I did upgrade of course before I posted my problem.
(3,166 Views)
