FieldPoint Family
Delay writing I/O's in FieldPoint
I have a problem with my VI when I load it in my FieldPoint unit. The program seem to be running very slow. One sylinder is to go out, return, and wait for a check (now set to DipSwitch 1), select the next sylinder -> Out -> In -> Wait for a check and so on.
My problem is that when I switch the DIP-switch I have to wait for 3-4 sec before the next sylinder moves. Anybody knows what can possibly be wrong?
(Also, my programming is no good, there must be an easyer way to do the described job...?)
Regards
Per-Otto
(3,536 Views)
Take a look at this posting.    It fixed a similar problem for me.
http://forums.ni.com/ni/board/message?board.id=110&message.id=4281&query.id=238893#M4281
(3,525 Views)
Thank you so much, you saved mye day (actually a whole week of trouble)!
And to make this thread usefull for others, this was the simple solution to my problem:
" To correct the pb you can create an empty file fpremote.ini and put it in the directory "ni-rt/system" of your target."
(3,504 Views)
