FieldPoint Family
Delays Writing to Compact Fieldpoint Device
Firstly, sorry for the repost, I posted to the wrong board last time.
When I write to one of the LED's on the cFP2020, sometimes there is a delay of 2 or 3 seconds before the LED operates. At other times it operates straight away.
I am using NI's OPCFieldPoint OPC server over a direct connection using a crossed cable.
Has anyone else come across this problem?
TIA
Tony
(3,454 Views)
Tony,
Try this:
Create an empty text file named "fpremote.ini" and copy into the directory "ni-rt/system" of your target cFP.
See this link for more info.  http://forums.ni.com/ni/board/message?board.id=110&message.id=4281&query.id=238893#M4281
(3,451 Views)
