FieldPoint Family
Differential Measurements with AI-10X
Is it possible to make measurement in differential mode on FP-A10X, using two channels to achieve this (like on E series Cards)? I saw that it's possible with dualchannel modules, but I need to measure [0-40V] signals...and dual chanels module can't...
(3,053 Views)
The only way to get differential measurments on non-differential FieldPoint modules is to use a single channel per module.
Note: the dual channel analog modules are not isolated channel to channel and share a common between channels so they can not be used differentially. The advantage for the dual channel modules is that you only lose 1/2 of the channels per module when performing differential measurements rather than 7/8 or 15/16 of the channels.
Aaron
LabVIEW Champion, CLA, CPI
(3,053 Views)
