FieldPoint Family
Dll Register server not found
I tried to incorporate Labview DLL on the VB6.0 Project, but i encountered the following errors:
1. when I register is on RGSVR32, it has an error "DLL Register Server entry point not found"
2. I tried to declare it in VB with the arguements based on the H file. But when I
it run the routine it has same error appear:DLL Register Server entry point not found
Pls advice,
(8,428 Views)
This message should probably be posted in the Labview forum.  It would get more visibility there, and it does not sound like it has anything to do with Fieldpoint or compact Fieldpoint hardware devices.
(8,423 Views)
