FieldPoint Family
Download problem in field point using LV8.2
Hi all,
I'm fresh user using compact field poing 2120  and LV 8.2 real time modules.
My problem is that, if I connect the PC and FP. I can start the VI inside the FP and run normally.
But if I disconnect the network the VI seems STOPPED. How can the VI run if network is OFF?
Moreover, I prefer the VI in FP run stand-alone and auto startup with/without network trigger.Does the FP have this feature?
Robert
由 Robert LAW 在 09-26-2008 07:17 PM
上編輯的訊息
(6,187 Views)
Robert,
You can use the NI-Application Builder to create a .exe from your VI and deploy it as a startup.exe.  Depending on the NI package you are running, you may or may not have the Application Builder.
(6,166 Views)
