FieldPoint Family
Elapsed time
I would like to make sure a process runs a specified number of minutes.
How do I program a elapsed timer to keep track of the time of a process? So if the process suppose to run for 5 minutes, the elapsed timer suppose to increment from 00:00:00 to 00:05:00.
(3,648 Views)
Attached is an example of an elapsed timer that will keep track of time as it is running. If you would like the display to be any different, please right click on it and select Format and Precision. . . or use some of the functions on the Time and Dialog palette.
Hope this helps.
Colin C
Colin Christofferson
Community Web Marketing
Blog
(3,648 Views)
