04-07-2010 03:35 AM
I would like to test functionality of my library on the other platforms. It is possible to emulate FieldPoint cFP-2210 in the LV2009? The part of our customers would like to use some vi from our virtual instruments library on the FieldPoint hardware, and I would like to test some vi from our library if there is some restrictions if they are running on the FieldPoint. The library uses VISA for communicate with our devices, other vi uses only standard functions implemented in the LV2009-Basic.
01:01 PM
- last edited on
10-20-2026
05:55 PM
by
Content Cleaner
Unfortunately the Field Point drivers do not allow you to create a Simulated Device in the same way that the DAQmx drivers do.
However, VISA is supported on FieldPoint and Compact FieldPoint as of LabVIEW 7.0 and later. As read in this KnowledgeBase article:
http://digital.ni.com/public.nsf/allkb/3165D9B90EE2F3D186256D240073A1EA?OpenDocument
Cheers
Logan H
