FieldPoint Family
Error -33156
I have used cFP several times in the past, but I have encountered a new problem with a RT application I have created which I have never seen.  The RT application which is running on the cFP I am using utilizes almost every IO in 6 of an 8 slot backplane, and almost all the in and outs have to be manipulated, passed somewhere, have calculations run on it, there are three PIDs, etc.  In short, the main execution thread is huge, and there are four smaller threads that handle datalogging, and communication via TCP to a GUI.  I only say this because I have never had a program nearly this big and complex running on a cFP, and I wonder if I have pushed the thing too far.  However, the main loop only executes every 100ms; I thought that would be enough time.  I have attached a screen shot of the subVI that is causeing problems.
Anyway, the problem I have is that when I start the application, several outpus from a DO-401 go high in response to a switch, then they are supposed to periodically go low, then high again, until the switch is turned off, at which time they all go low, and stay low.  To simplify the code, I have the FieldPoint write and read functions in For Loops, whcih I thought also might be the cause of the problem, but I don't know why.  Anyway, often, when I run the program all the outputs will be written to once, and then, especially with the DO-401, none of the values will update.  That is, the program is definitely sending the right address and value to the cFP, but the DO module doesn't respond, although sometimes it does.  I tried setting the On Change parameter to both turn and false, but it didn't seem to make a difference.  The only thing I have to go on is error code -33156, which I can't find a definition for anywhere.  I sometimes see this code as a result of the FieldPoint write finctions, though not always, usually there is no error.  Also, I tried putting all the writes in one For Loop, but that didn't make a difference.  I even made anouther program that only contained a for loop which wrote to the same DO channel multiple times, and it didn't work either, which makes me think that the problem has something to do with having the FieldPoint Writes in a For Loop.  I haven't had time to check this theory, but I don't know why that would cause the problem.
Jo-Jo
(4,288 Views)
If you do a search on the forum for error codes, make sure you search as 33156 as opposed to -33156.  I believe I remember seeing that the - sign tells the search engine only to return entries that do not have 33156 in it, which would be every other message besides the ones you want.  I found only 1 message in the forums for a search of 33156 which is below.
I also entered 33156 in the explain error... menu item under help and got this.
"Error 33156 occurred at an unidentified location
Possible reason(s):
FieldPoint:  The device is offline. Make sure the device is connected and its power is on."
If I were you, I would take a closer look at the semaphores.  It is hard to see how they are working or what they are doing as a lot of that code is off to the bottom right of your screen snapshot.  I see the semaphore reference is passing through a couple of for loops in series making me worry about dataflow issues.  I wonder if there is a possibility that somewhere the semaphore is being locked and never getting released, and that is preventing other portions of the code from executing.
(4,276 Views)
Thanks for the help.  I have found the issue.  There was a bent pin on DO cFP module (whoops).  I didn't bother to check to see what the pin was, but it was one of two pins that are longer than the rest, and due to the intermittant nature of the problem, I assume it was a ground pin.  Anyway, problem solved.
~Jo-Jo
(4,267 Views)
