FieldPoint Family
FP 1000 Network LED
when i power on the FP1000 the LED Power is on : it's normal
but the Network LED is also on.
There is no module or PC connected to the module
What's the problem ?
(6,183 Views)
Hi!
   Does it shut down (the Network LED) when you connect the PC?  Do you leave a cable attached to FP-1000 on one end, and to nothing to the other end?
   Once I had a problem with a RS232 cable connected only on module socket, and left unconnected at the other end, but actually it wasn't a NI device, so I'm guessing...
graziano
(6,168 Views)
