FieldPoint Family
FP 1001 - Unexpected character from Optomux error
When I try to access my FP 1001 module, FP explorer gives me back an
error "Unexpected character from Optomux". The module is the second in
the RS485 network. The first and the third work perfectly. Of course I
tried replacing the module with a new one. I found no support around.
Any idea?
Thanks in advance,
giovanni
(3,139 Views)
Giovanni,
An "Unexpected character" message generally means that one or more of the characters in a message string was corrupted. The primary cause of this on serial lines will be improper termination or noise. For RS-485 communications, you should be using two pair twisted shielded wire, with one pair having the Tx lines and the other pair having the Rx lines. The lines should be terminated at the source (computer) and the final transceiver (last FP-1001 on the line) with 120 Ohm resistors. The resistors should be placed between Tx+ and Tx- and Rx+ and Rx- (see page 8 of the FP-1000/1001 Quick Start guide http://www.ni.com/pdf/manuals/322731e. pdf ). Note that with a multi-drop RS-485 configuration, it is recommended that a daisy chain configuration is used ra
ther than a star topology.
Aaron"
LabVIEW Champion, CLA, CPI
(3,139 Views)
