FieldPoint Family
FP-1600 Communication Loss
I have an FP-1600 module that works fine when initially powered up, then stops communicating after several minutes. The module indicates that the network connection is still there. Any ideas other than a bad module?
(3,370 Views)
Justin
Make sure you have the latest rev. of the FP-1600. Are you using the ethernet interface? Check what error you are getting. If you are getting error 33163, you can trap the error and recover. In my situation I have noticed these errors occur due to electrical noise.
Steve W.
(3,370 Views)
