FieldPoint Family
FP 1600 Status Led Blinks 7 times Firmware 4.11
LabView 6.1 FieldPoint 3.01 Datalogging and Supervisory Control, FP 1600 Firmware 4.11, FP RLY 220,AO 220,AI 111,RTD 122
I am using multiple Vi to read I/O using Read/Write tag Vi's of DSC Module.
I had properly set the IP on FP 1600 and the Host PC is able to communicate the module. I am able to read values and write value to the channels.
But after a few hours of operation (4 to 5 hours) the Status Led starts blinking 7 times. And after few more hours the Host loses communication with the FP 1600 module.
I had used the FP 1600 Diagnositic Utility for defect detection. The Power supply is fine and the the temperature is also in limits.
Does anyone have a solution to this problem.
(3,940 Views)
First I would recommend that you redownload the Firmware to the FP-1600. To do this refer to the following web site:
http://zone.ni.com/devzone/conceptd.nsf/webmain/1847F7109031B6FD86256AA30070040D?opendocument&node=174401_US
Next, I would recommend using most recent version of FieldPoint Explorer which can be found at the following web site:
http://digital.ni.com/softlib.nsf/websearch/7C99C563A473BC8686256B520056A923?OpenDocument&node=132060_US
If you are still seeing the Status LED blink 7 times, contact National Instruments Automation support for further help.
Best Regards,
John M
(3,940 Views)
