FieldPoint Family
FP 1601 status led shows red continuously
I am trying to use FP 1601 which was already configured long before. But now the status LED is continuously red .Power LEd is green and all other LEds are off. Am giving 24V power and checked that it is given to V and C properly .Ethernet connection is also proper. i tried to reset , but could not. i cant use it in anymore. can anyone help in troubleshooting
(6,107 Views)
The status LED can actually lend useful information regarding the potential culprits to your issue. You can check out the STATUS LED Error Indications in the 1601 User Manual.
In this case, it looks like you should contact National Instruments directly since it seems as though the module did not power on correctly. You may have to return your unit for replacement or repair.
Cheers,
Emilie K. | Applications Engineer | National Instruments
(6,096 Views)
