FieldPoint Family
FP 2000 firmware error
My FP2000 is blinking twice with status LED after firmware upgrade(The FP-20xx has detected an error in its firmware.)
Before upgrade everything worked fine.
DON'T REPAIR WHAT'S NOT BROKEN! is my advice.
How can I repeat/undo upgrade process. Max claims OS ver 10.4 is installed. Formating disk and reloading everything does no change. I did this upgrade quite a time ago, so I dont remember the exact procedure how I did it. It is demo equipment, so I left problem unsolved then.
(6,365 Views)
Hello Damir,
The following link contains detailed informations on how the Firmware on FP can be upgraded.
http://zone.ni.com/devzone/cda/tut/p/id/4466
Regrads,
Emil
(6,346 Views)
