FieldPoint Family
FP 2015 and SRM 6100
Hello all,
In my lab, I have 2 SRM 6100 modem (one is a Master and one is a Remote) and 1 FP 2015, 1 FP DO 400.
I have connected SRM6100 Master with Laptop ; SRM 6100 Remote with FP 2015, FP DO 400. I just want to write a program in Labview in order to Turn on the Led in FP DO 400.
However, i can't see the FP 2015 and FP DO 400 in Labview via two SRM6100 modem. Therefore, please give me some advices ?
Phong
(6,638 Views)
What version of the LabVIEW Real-Time Module are you running?  This device is only supported by LV RT 8.5.1 or earlier.
(6,625 Views)
Hello Wayne,
I use Labview 2010 and Labview Run-Time 8.6.1. So, I must install another version of Labview Run-Time ?
Best Regards,
Phong
(6,613 Views)
Hello Wayne,
I had installed Lab view 2009 with Labview Run Time 8.6.1. In MAX, i can only see the Master SRM6100 through NI-VISA (ASRLxx:INSTR), the FP2015 in the Remote SRM6100 does not appear in MAX. Therfore, i can not access to it and FP DO 400.
Please give me some advices,
Phong
(6,608 Views)
You will need LabVIEW Real Time 8.5.1 or older and the version of LabVIEW that is compatible with that version of Real Time.
(6,597 Views)
