04-19-2006 09:07 AM
04-21-2006 03:56 PM
Hi Robert,
I got a chance to talk to a few of our developers and I found out that there is
no minimum resistance requirement for the FP-AO-200.
Essentially the Short Circuit protection circuitry will only trigger if it
senses that the amperage is going over 20mA. So 56 Ohms shouldn't be a
problem. You may want to confirm with an Ammeter or Voltmeter what the
Current/voltage is across the resistor. If for some reason it's going
over 20 mA then that would give you the fault situation that you are noticing.
