FieldPoint Family
FP-DIO-550 - Can you write to all output channels at once?
I have tried to create an item in MAX which will allow me to write to all output channels at the same time, but have not been able to make this work.  I can write to each channel, but then I need to do 8 writes instead of 1.  It would just be cleaner to do it the other way.
Please advise,
John
(5,973 Views)
You absolutley can, the best way to do this is layed out in this knowledgebase article: http://digital.ni.com/public.nsf/allkb/86AD45702FF1E71986256B4300644E45?OpenDocument  If you are using a project explorer, the process is very similair to the MAX example.
(5,952 Views)
