FieldPoint Family
FP TC 120 Output
Hi everyone,
I will be using the FP TC 120 module to measure several temperatures using thermocouples. My question is that if I use FP Read to read the output from FieldPoint IO Point In which corresponds to a certain thermocouple, will FP Read give me an actual temperature reading or just a voltage? If it's the latter, how can I convert that voltage into a temperature? Thank you.
(6,213 Views)
It will give temperature.
You just need to make sure you configure the channel for the correct type of thermocouple.
(6,210 Views)
Thanks RavensFan!
If you don't mind, I had another unrelated question. If I'm using the PID VI from the PID and Fuzzy Logic Toolkit, is it possible for the VI to output a negative value? For example, if my process variable is above my setpoint, would the VI return a negative value?
(6,185 Views)
I think so.   But I'm not sure.
Just start playing with it and find out.
(6,183 Views)
