FieldPoint Family
FP TC-120 readings freeze after about 30 minutes
I have a very simple VI that controls heaters in a chunk of steel.   The steel has four thermocouples(one for control and three for monitor).
The VI loops and looks at the setpoint and the control TC reading.  A boolean determines if heater is turned off and on.
Everything runs great for awhile (usually less than an hour) and then all the TC's "freeze" into a reading that is just slightly higher than the setpoint.  Consequently the heater stays off and everything cools to room temperature.
I'm using a TB-3 and V/C are not hooked up.   This problem happens if one thermocouple or all of them are hooked up, it makes no difference.
I'm at a loss for ideas.  I do very similar things with other TC-120s at my facility, but I can't swap them since they are all currently in use for testing.
Any ideas?
(2,997 Views)
For anyone watching, it seems that TRCErin has worked out the problem according to the results in this other thread.
Thanks-
Tom W
(2,984 Views)
