FieldPoint Family
Field point scale?
Hello all,
I need to make a *.vi where a user can edit the scale of the Field Point Channels easily.
That means read the current scale, edit and then save it.
MAX should not be used.
HW used: FP 112, Ethernet
(8,556 Views)
By scale, I assume that you mean range.  And while I'm not sure if you will be able to read the current range you can set the range using the Configure Range.vi from the FieldPoint palette.
17377i43A2227A0DE074CA
Hope this helps.
Justin Parker
Product Support Engineer
(8,541 Views)
Hello
Justin_P, thanks for the replay. But, this is not what I was looking for. I need to change the scaling (Slope and Y-Intercept).
For example: MAX->Data Neighborhood->FieldPoint Items->FP-AI-112@2->Channel 0->Scales.
I need that a non-experienced user can use my *.exe, and change the scaling. Then this change is remembered in the project *.iak file.
Can you help me?
(8,533 Views)
Use the basic math operators of add and multiply, add your offset (b) and use multiply for slope (m).
Y=mX+b
Or I think there is a linear interpolation function in one of the pallettes.
-AK2DM
(8,522 Views)
the_sun:
See attached code I have used before.
-AK2DM
(8,516 Views)
Hello So, I have done something similar, but this solution does not solve my problem. I need that the changes are read/saved from/to the *.iak file. Something similar to DAQmx, where all the changes for each channel, task or scale, made in some *.vi, are saved in MAX Have a nice day
(8,492 Views)
I would take AK2DM's suggestion and then save the m's and b's to another file that you make on your controller, called something like scales.ini. I wouldn't suggest trying to modify the .iak file to include your scales.
If you could explain to me why you need the scales to show up in MAX, maybe I would better understand your problem and be able to provide a different solution.
Justin Parker
(8,476 Views)
