FieldPoint Family
FieldPoint and simulation interface toolkitHi
Hi i'm trying to use cFP-2010 (with cfP-AIO-610 module) with simulation interface toolkit, in MAX i can see the FieldPoint and it's modules and i think it's all well configured.Well when i open the SIT i choose Real Time Target with the cFP ip and the port where the SIT server is running after i go on Hardware I/O and when i try to configure NI FPGA i do add device and it's return :"labview did not detect any FPGA devices installed in the specified RT target ,The default hardware type PXI-7831R will be used".Where is the error?
THX
(4,610 Views)
Hello Freddino,
is the Simulation Interface toolkit installed on the RT target you are planning to use as SIT server (in your case the cFP 2010)?
After have configured you RT target properly, it may be correctly listed unded "Hardware I/O" into the SIT connection manager.
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(4,592 Views)
